Hi 88canadianvette,
Did you ever find out anything about your high idle situation? I've got the same problem with my 87... idles about 8000. I have set min idle speed and TPS a couple of times with no results. In fact, with the IAC closed and disconnected, I can't get it to go any lower than about 750, and that's with the throttle body screw backed out so that it doesn't even touch the throttle. Seems like it must be a vacuum leak, but I have been over it with a fine-toothed comb and found nothing. I even swapped out the throttle body, but the idle didn't change.
It's funny too, with both throttle bodies it is hard to tip-in the gas from idle. No matter how gently I try to feed in the gas, it will often suddenly jerk down, sometimes revving the motor to 2000rpm. Kind of annoying sometimes. With the engine off, the gas pedal operates smoothly. With the engine on, it doesn't want to crack the throttle plates open smoothly... like it's a vacuum lock or something.
