M
mdsbch
On my 85 coupe, I am getting a code 52 (CALPAK missing) as well as other intermittent codes 53 (System over voltage) and 54 (Fuel pump voltage low). The last two are intermittent and don't always come up, but every time I do a scqn with my AutoXray, the code 52 shows up. I know it is there, because I replaced the ECM and had to swap the PROM and CALPAK over to the new ECM. The previous ECM was throwing the same codes. If anyone knows of a way to test the CALPAK or even where I can get another one (prefferably new, but a used one that is known to be good would work) would be greatly appreciated. I already talked to RockAuto since they had one listed for an 85 with manual trans, but I have an automatic and they say the one they have will not work and the one for the automatic has been discontinued. :ugh
Mike
Mike
