Bills03Coupe
That time again to change the differential fluid in my 03. Going to use Mobil 1 Synthetic gear lube LS, 75W-90.
My question is, the lube contains the limited slip additive and states no more is required. I've also read many advise to use the
GM additive* in addition to what is in the lube. Any feedback from those of you that have used this lube would be appreciated!
*Also, the GM 1052358 is no longer available, and GM88900330 is listed as a replacement, correct?
