Modifying an LT1 Corvette - To Top It All Off
Missoura Ozarks
2012 💯 4LT GS Roadster
MODIFYING AN LT1 Corvette for improved performance can be a trying business. Aftermarket parts are scarce, the work itself is often maddeningly difficult, and even the most intrepid Corvette tuners may be inclined to treat you like an end-stage Ebola victim. Given these hurdles, we were pleasantly surprised to learn of Trick Flow Specialties' new Fast as Cast GenX LT1 top-end kit, which should be available by the time you read this.​
Carrying PN TFS-K304-430-400, the package generates a claimed 430 horses and 400 lb-ft of torque when installed on a healthy, stock-displacement LT1 engine. If accurate, those figures would put a '92-'96 Vette's output on par with Bowling Green's latest, and restore much sorely needed performance credibility to the aging Gen II small-block. We'll be installing the full kit on our '96 C4 coupe in the weeks ahead, but for now, let's take a closer look at the package's specifics.​
Heads TFS has offered GenX LT1 cylinder heads for a few years now, but the company's first effort employed largish 195cc intake ports and was intended for stroked or forced-induction engines. The new Fast as Cast version relies on a downsized, 185cc port that makes it ideally suited to naturally aspirated, stock-cube combinations. As the name implies, these heads are designed to offer superb flow right off the shelf, eliminating the need for costly and time-consuming port work...
To Top It All Off - Vette Tech
Hey What about us with the L98
Lt1 are great but what the !$#@ Wheres the L98 stuff....
L98 stuff? Its a Gen 1 small block your options are limitless as regards to good cylinder heads. Might need to get rid of that TPI intake, but aftermarket has that covered too in SO many ways. Just takes some pocket change to get the stuff. Always the problem. :thumb
