W
WhiteKnight
The motor is a '71 L-48 with auto tranny. If I leave it in drive it will shift around 4000 RPM 1-2 shift. With the selector in 1st it will bog a little over 4k then it almost sound like its missing but makes it to 5300 and then shifts to second. If I manually shift to second when it first bogs all is fine until around 4500 in second. I thought it might be ignition related and since I was repalcing the distributor (HEI unit no mech tach drive) with a points unit w/mech tach drive (thanks Jack ) I also replaced the plugs, wires and tach cable, added a coil and balist resistor. I can now see the RPM at which this happens rather than calculate it based on speed, tire diameter and gear ratio. However, the problem remains. I thought it might be fuel starvation so I replaced the fuel filter and also found the accelerator linkage not adjusted to open the secondaries fully at WOT. I made the adjustment and that gave me 200-300 more RPM but still the bog happens. Note the carb is from a '74 454 (Carb Rochester Q-Jet: 7043201 = (1974 454ci 275hp man trans). Not sure if that matters, it has a mechanical choke and it seems to operate properly (closes when cold with the first pump of the peddal and opens when warm).
Compression test #1, #3, #7 - 130, #2 & #4 - 135, #5, #6, #8 - 140.
The old plugs # 1, # 3 & #7 had carbon deposits. The rest were normal.
When first starting it will smoke (blue) a little from the drivers side, but if I shut it off and re-start, no smoke.
Revving the motor with no load, it revs fine all the way to redline, yes I only have done that after warming up the motor. No miss.
What next? I'm thinking either something in the trans is messed up.. or maybe it's the carb, but since my knowledge is from reading more than doing lately. The last time I rebuilt a motor was in high school auto shop 22 years back. I need advice.
