J
jon79flavette
I am having a problem with the 350 sbc recently put into my 79. I am pushing oil out the dip stick, the dip stick is new and correct. I am also (at times) blowing the oil cap off the valve cover. The oil level is correct at 5 quarts, it is not over full. The interrior is removed and there are no gauges in the car. I could put an external oil pressure meter on it. The motor is a 70 LT-1 .30 over. a 280/520 cam. edelbrock intake with 750 cfm carb. Is it POSSIBLE that the motor is back pressured too much. This car sat for a long time. I have the stock exhust including the original cat converter. I know this is not the right exhust. It with have hooker side-pipes, but I don't have them yet. Could the exchust (restriction) and or clogged cat cause this problem??? any other suggestions. I can provide any additional info. This is getting me frustrated. Thanks Jon
