MP3 Hook Up on a 97
T
tuckerdawg
Can anyway give me any ideas for the best/easiest way to hoop up a MP3 player to the stereo system - realizing that these are likely two completely seperate issues (best vs. easiest). Thanks!
AUX 10 from PIE; as long as your factory head unit has the word "BOSE" on it.
AUX10 unit
It appears that the AUX 10 is only for trunk mounted units, which I don't have. Will this also work on a standard Bose in-dash unit? Appreciate the website!
Give them a call, I believe there is a way to do it. I've also heard that even w/o the 12 disc unit installed, the wiring harness may have been included on the head unit. I'm not sure where the easiest place would be to verify it though.
The Answer
I contacted the company (PIE) and they wrote me back the following (below). I'm gonna order parts and give it a shot
___________
We do have parts that will work for your 97corvette. These are the part
numbers
1-Part # COR-HAR
1-Part # GM10-AUX
The COR-HAR is the cable that will allow you to use the aux because your
vehicle is not prewired. You will
be plugging it into the 3-pin and 4-pin connectors under the carpet of the
passenger seat foot panel.
And the GM10-AUX is the aux input for your audio sources which uses
RCA's in
Thanks,
If you have anymore questions, feel free to email me at frankg@pie.net
Great! Let us know how it all works out and how you installed everything. Take a few pics and post here when done.
