SMOKINGJOE
Hi All
I installed a Crane Cams XR-I point conversion last year and have been happy with it. Now I’m installing an MSD 6 ignition box. I mounted the box under the right front fender above the heat/blower motor. Everything fits very nice and it runs better then before. My question refers to either connecting the wires on the Ballast Resistor with a strap of wire between the terminals or removing it. Maybe I can use a connection block of some kind. MSD does not required a Ballast Resistor so I looking for some ideas. I like the change to look good.
If I jump out the resistor, what gauge wire should be used and is that good to do.
Anyone have any ideas
