S
Stingray72
Hey all,
I'm about to install a complete MSD setup including distributor, 6AL box, and plug wires. A lot of the wiring in the car is in pretty bad shape including the old, white cloth-wrapped resistance wire which currently goes to the + side of the coil and will be called upon to turn the new ignition on and off. I would like to replace this wire. Does anyone here know where it terminates and how to get to it? Does it terminate at the ignition switch or the main wiring harness? Is it easy to get to, or should I just leave it an bypass it with a new wire until I can really tear into the wiring system? Has anyone had any experience with this?
Thanks a lot!
Thanks a lot!
