WLS Ruby 93
I am trying a muffler modification which is new territory for me and hopefully it will work out.
The premise is that if the mufflers are opened up, some internal changes made and then resealed that the exhaust gas flow will increase and hopefully give better performance and maybe even get a little more rumble from the system.
The attached pictures show what I have done so far.
Create a steady rest using two "Workmates".
http://www.corvetteactioncenter.com...aust-modification-picture2433-steady-rest.jpg
Outline drawn for the cutout on the bottom side of the mufflers.
http://www.corvetteactioncenter.com...aust-modification-picture2432-cut-outline.jpg
Using an angle grinder with a cutoff blade, cut the section outlined. Notice the support bands come free be sure to index them for the refit.
http://www.corvetteactioncenter.com...ust-modification-picture2434-band-removal.jpg
Drill out the spot welds which holds the wall to two baffles on the inside. Remove the cut panel.
http://www.corvetteactioncenter.com...fication-picture2435-drill-out-spot-welds.jpg
The inside revealed. what we have there is the inlet pipe on the right with perforations leading through two baffles but not a continuous pipe (notice the space between the baffles), into a chamber and two outlet pipes with perforations that are wrapped in steel wool. The mod is to cut two 2 inch holes on the solid baffle to allow the gasses to escape directly through the exit pipes from the large chamber.
http://www.corvetteactioncenter.com...modification-picture2436-muffler-interior.jpg
My next move is to reseal them by welding and give them a try. The only thing I couldn't do in my amateur work shop was to cut the holes in the baffle. I brought the mufflers to a local metal shop and for $38 the guys plasma cut the holes for me.
I will record the sound difference between the unmodified stock setup and the modified mufflers which some how I'll get posted so that others can hear the difference if any. Then I will be watching the performance and the gas mileage to see if there is any detectable difference.
This may take some time since Christmas is rapidly approaching and I have other things to do. This at least gives everyone a "Look/see" on the inside of C5 mufflers.
Also, this is a second set of mufflers to experiment with my stock set will remain of the car until the swap.
More pictures to follow, I hope these pictures work out OK.
Keep 'em rollin' :W
Bill
Keep 'em rollin' :W
Bill
