bucket
does anyone have experence in removing the muffler and just using the converters to...well...you've got it figured out by now...
hnoes
THERE IS A BALANCE BETWEEN PROPER BACK PRESSURE AND TOURQUE...
OPEN IS BETTER FOR WOT HORSEPOWER
BUT..I'M THINKIN THAT THE CONVERTERS WILL SUPPY PLENTY OF BACK PRESSURE
Fine when your engine idles at 1500rpm and only goes 1/4 mile at a time.That is why drag racers use open headers!
BTW, the cats do most of the muffling anyway, so sound wise, running straight pipes from the cat back will not be TERRIBLY loud.
I wouldn't say that is entirly true. My ride is a retired A/S SCCA car. And you were permitted to run altered exhaust with the approval of the officials. It had straight pipes. Extremly loud, except when at idle, anything over 1500 RPM was annoying to say the least.
tcxd40
This is a MYTH! Back pressure will NOT produce power, PERIOD!(snip)
On Mass Air Flow systems, there's not even the need to recalibrate the carb. The MAF system automatically compensates.
At WOT, the ECM runs in power mode. If the exhaust is too big, the stock ECM will run lean, and you are kissing power goodbye. Just connect a scanner and drop the rear y-pipe and mufflers and watch the results. You want a scavenging effect in the exhaust system, which is maximized when exhaust air velocity remains high with minimal back pressure. Zero back pressure reduces power below the torque peak. There is room for improvement with the stock exhaust, but the L98 is plugged up on the intake side, so don't go crazy and end up reducing low end power.
Your best bet is a well-designe, "catback" exhaust system. Flowmaster is a good compromise between performance and price. On a 92 LT1 with a stock or near stock engine, the gain will be 5-7hp and the resonance will not be near as bad.
