As I was trying to fix my power door locks, I found a connector under the passenger side dash that wasn't hooked up to anything. It is a black connector and it has a dark blue wire and a black wire with a purple stripe coming out of it. Does anyone know what it could be for?
Off the top of my head, I have no idea. Can you get a camera in there to take a picture, then maybe I could check out my service manual. Someone else might now as well.
Does your car have bose or a power antenna? If not this may be the plug for a factory bose speaker amp and a power antenna lead. Just a guess, but the colors match.:ugh
Yes, the RPOs say I have the bose 6 speaker system, although i can only find four. Everything for the stereo system works, except for I have the two front speaker enclosures unplugged because I need to replace the amps. The factory system is still installed.
