Need A Picture....
Eddie 70
Kingston, Tn
1970 Convertible LS6 and an 02 EB Z06
Of the backside of a front bumper off a chrome bumper vette. I just took my front bumper off and I think Bubba has had his way with my bumper. I need to see the area where the bolt goes into the bumper.
Any help would be appreciated.
You can go to websites like Pargons or ZIP. Often there are pictures there.
The MAD catalogs have great diagrams of bumper parts...etc, that allow you to see what is behind there.
Also, an assembly manual will put you right where you need to be.
Basically there is a vertical brace that comes up from the front frame support. It goes just up inside the nose. The bumper had two holes in it that line up with the vertical support. One side is slotted for adjustment. You can shim, bend, grind..etc. the vertical support as needed to get it to line up right. There is also a skinny single rod that runs from the core support foward. It bolts through in the center up the vertical support.
All of this kind of tucks up right under the extreme front nose of the car.
