Need Help 1992 corvette right side of motor floods
Johnr
New member
pa
1992 base
Need help my corvette right side of motor fills exhaust with fuel. Have cleaned all grounds replaced fuel regulator injectors optispark module
check injector wiring with noid light left side has pulse right side real bright and no pulse. can you by pass the wire from the ecm to injectors to see if wiring is the problem if so witch wire from ecm sends pulse John
Have you done the fuel pressure tests in the Factory Service Manual?
