1984 corvette in need of help
In need of help
New member
Mobile Alabama
I have just bought a1984 corvette that has setup for around 3 years the car was running fine when it was parked with that being said I turn the key on all dashboard lights up but the starter will not spin over at all all so the injectors are not getting power I hooked up a pushbutton switch from the battery to the ignition wire on the starter poured some gas in the throttle body's hit the pushbutton and she fire's right up and runs until it burns the gas that I poured in it. I checked the fuel pump and filter every thing there is good i went ahead and changed the ignition cylinder hoping that might fix the problem but that didn't help the problem all the fuses are good i bought the ignition switch and am thinking of changing it next but it's going to be quite a job being you have to drop the column down and all that and there's surly no room under their to work i also have jumped the neutral safety switch and that didn't help the problem either i was wondering if this problem could be in a open circuit in one of the relays any information or help would be greatly appreciated I'm sure someone else out there has had this problem to thanks
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
Welcome to the Corvette Action Center. I'm going to move your thread into the C4 tech forum for greater exposure...
ecss
Windsor Mill, MD
89 Brilliant Red Metallic
Assuming there is no aftermarket alarm installed.
You need to gain access to the starter interrupt relay located behind the DIC driver information center.
Below is a picture of the relay.
If you remove the relay and jump the Purple wire which goes to the starter solenoid to the Dark Green/White wire which goes to the neutral safety switch and turn the ignition switch to start the starter should engage.
If it doesn't you need to verify there is 12 volts on the Yellow wire of the Neutral Safety switch when the ignition switch is in Start.
If no 12 volts, probably the ignition switch is bad or it's not adjusted correctly. It's mounted on the steering column and can be moved up and down.
If the starter does engage when you jump the Dark Green/White wire to the Purple wire when you turn the ignition to start, something is wrong with the Theft Deterrent Module. It energizes the starter interrupt relay if the alarm is set and either door or hatch is opened and disables the starter.
