70 RED 454
I may not have the terminology right, but in my 70 I have to have the 4 speed in reverse in order to turn the ignition key.
Problem is the lockout doesn't always engage fully and I cannot turn the key. I've been able in the past to grip the steering column and rotate the movable lockout sleeve just enough to engage it and free the ignition switch. Since then I've had the dash apart fixing wiring issues and needed to 'lower' the steering column to remove the panels. I've now finished and rebolted the column to the dash bracket and tightened the bracket at the fiewall. Problem now is putting the shifter in reverse does not engage the lockout at all......meaning I cannot see the sleeve rotating when shifting into reverse. Fortunately (unfortunately)....the key was in the ignition when I started all of this and I cannot get it out (although I can start it and turn it off).
I've fiddled with the positioning of the firewall bracket in order to maximize the throw of the wire coming from the transmission (to engage or rotate the sleeve).......but no go. I've reread the steering column instructions in the assembly manual so many time I know the steps by heart.......but to no avail.
Can anyone tell me how to fix this? I can move the lever attached to the sleeve by hand but I cannot get the key out.
