P
packen
I had this posted at the Corvette Forum but they ran out of answers so here's my problem.
1984 crossfire, stock. Runs fine when it's cold but once it's warmed up and you shut it off, it will not restart for about 15 - 20 minutes.
No trouble codes from the ECM.
Installed new ICM, new fuel filter.
Fuel pressure holds at 13 psi and stays for at least 45 minutes after shutting down.
Checked injectors with a noid light after recreating the problem. It was hard to see because of being in direct sunlight, but looked like one of them had no signal and the other was very dim. I tried this test while the engine was cold and they both were very bright.
Once the car is at the point where it won't restart, I can spray a little starter fluid and it will fire. If I pump the accelerator after it fires with the fluid, sometimes it will continue to run.
So, anybody have any ideas?
