Need Help Getting Interior Door Panel off 93
  • Thread starter Thread starter bstie
B
bstie
Need assistance getting my interior door panel off the passenger side so I can work with window adjustments.
I have taken out all the obvious screws but the thing does not want to come off. Any ideas? Is there a hidden screw someplace?
Thanks,
Brian
door panel
Brian -
You may need to supply more info before someone can help you.
Is the panel loose anywhere - front or rear edges?, corners? top?, bottom?
Does it seem to be more tightly fixed at any one place like top or middle?
Have you tried to slide the panel vertically towards the top before pulling it away from the door?
Terry
Door Panel not coming off
Pretty much seems to be right in the middle of the panel like where the door handle is. No bolts or screws there though other than the 1 small one that holds the plastic piece on...
