Need help with L98 timing
  • Thread starter Thread starter aoriii
A
aoriii
I've been working on adjusting the timing on my 85 L98. The timing was so far off, that I'm suprised that she started every morning( but that's another thread).
My question: do the hash marks on the timing indicator indicate 1* or 2 *? According to the documentation that I have, the car should be timed 6* from TDC on spark plug #1. I did this (assuming each has mark is 1*) and the car starts fine, but it idles @ about 850-1000 RPM, and will idle for a minute, then cut off. I can prevent the shutdown, by leaning on the gas, but...
In a previous thread, several people have noted timing their cars at up to 9* from TDC. Assuming that each mark is 1*, then there are no room on the scale for 9*.
So...what's the truth here? 1* or 2* per hash mark?
HELP!!!
and Thanks
Trey
On the 85 the wire is Brown with a Black Trace. Be sure the car is at operating temp when timing. I used to run at 10 degrees before having to take it down to 6 after doing some mods and chip to avoid detonation. Each mark is 2 degrees. I would suggest setting the proper timing and then using the proper procedure for setting the idle and check TPS setting then take it from there.
Hope it helps some.
Carlo
