LT4 NEED HELP WITH LT4 MOTOR
  • Thread starter Thread starter bigtodd08
1996 LT4 Topic
B
bigtodd08
I HAVE put a new fuel pump and a new fuel filter on and new plugs and wires and new ignition coil with a new ignition control module and new fuel injectors....I still cant get this thing to run right ??
I have a 1995 trans am firehawk with an Lt4 motor..and I know i have 94 opti-spark I have read alot this is the only thing I havent changed along with the water pump....
any thoughts
Could you give me some symptoms you are experiencing?
Does it start well cold?
Does it have a high idle when cold?
Does it bog down when hot? At low speeds? At high speeds?
Any "Check Engine" lites coming on?
SAVE THE :w
nope
car starts fine when its cold then starts to run poor sound flat thru the exhuast I do have a high perform cat with the slp cat back exsht..on it so you can hear the difference. There is no smoke there is no lifters tapping and there is no check engine lights on ..
I hooked a ob11 snap on computer onto it and has spark cylinders all fired right ..
this thing is killing me I have checked all the connections and have had most modules checked, The guy at the chevy dealer Hates this car ..
I have had the cylinders pressure checked as well even had vavles checked they looked good..
I know the motor is not in a Corvette, but it's still a Corvette motor, so I moved this thread to the C4 Tech forum. Hopefully you'll have better visiablity here.
Jason
OIL SHAFT SEAL
I had the car at our local corvette dealer and they did a very good test which was only 90 dollars and they finally figured out whats wrong..
The Oil shaft seal is leaking and causing the distributor to foul out.So My new question is I bought a new Distrib,
OIL SHAFT SEAL
does anyone know if I change the ditributor does that include the oil shaft seal or is this a seperate part???
anyonw know how to install this thing????
What shop did you take your car too? I used to take my '78 to Stallion Corvette, in Virginia Beach all the time.
Good luck with the replacement. :upthumbs
Jason
No, the OptiSpark Distributor will not come with the oil shaft seal.
Your friendly, neighborhood, Chevy dealer will be able to sell you the seal.
OR you can call Chris May at Superior Chevrolet at 1-800-728-8267 and tell him Gregory in Chicago told you to call him.
SAVE THE :w
