M
Moonunit 451
Need input and advice on motor rebuild/Next Chapter
I got my motor out about a week ago, didn't find anything catastophic. I can't figure out what was causing the noises I was hearing. I hope it wasn't the tranny after all this. The bearings and crank were marred up some and it looks like the oil rings probly just got tired. In addition to #8 which had been fouling badly, when i pulled the plugs #'s 4 and 6 were also pretty fouled. Everything else looked pretty good. There was some copper dust in the bottom of the oil pan.
The bearings were all silver, no copper
I've been doing some rudimentary research on parts. I've learned that it's gonna cost more than I thought, no matter what. I'm trying to figure out what to do to get the best I can for the least cost. I've got ported polished stock cast heads, comp cams 1.6 rocker rollers, 219 LPE roller cam, Eagle forged rods, and a SR with TPIS bigmouth intake comming (still waithing to finalize transaction). I've also got a line on some used 10:1 CR flat top forged pistons, ? with forged rods for a very good price. These are for a .30 over bore.
This car will be a daily driver and I plan to quarter mile some, do some road track time occasionally and maybe a little autocross now and then. I'll probably keep it normally aspirated. It'll be driven aggressively frequently. I plan to deck the block and balance the rotating assembly. I'm not planning any major transmition or rear end changes at this time.
Questions at this point.
1. I know no one would probably recommend used parts, but is there a way to
test for the integraty of the pistons, rods, and block that would reasonably
confirm their worthiness?
2. I've found a four bolt main block casting #3970010. I've been told these
are good blocks to build. From waht I can determine this is a 69 to 80 GM
bulid. Should I use it instead of my stock casting 1408858 2 bolt main?
Unfortunately the 4 bolt has a cast crank as well, so no luck there.
3. Should I really be that concerned with using a forged crank (or other parts)
and what about mixing forged and cast parts?
4. What is required to be done to the block to install the roller cam?
I'd appreciate any input, keeping in mind that I hope not to spend more than about $2,500 to 3,000 total. Let's say that with what I've already mentioned I'm already in over $1,500 and I still need all the standard stuff for a rebuild and the required machine work that I'll probably have to pay retail for. The R&R and all labor I can reasonably do are on me. I also have some aquaintances who do some performance engine work, but I don't know how much help I'll receive from those sources yet.
