Question: Need relay
Hi, anybody know where I can buy a 1989 c4 relay for ABS system? Thanks for any help:)
look the map on the relay and go to a shop a search a relay that has the same map, if dont, look the number, if dont, go to General Motors and buy the relay there!
Good Luck!
it turns out the relay was ok and a bad connector was the cause of the problem.
Ahh, good on ya for finding it. I find that contact cleaner and small brushes are essential tools on all modern cars.
Mine had a fuel pump problem; found the old wires, on adjacent (A&B) terminals in the relay plug were touching, exposed due to age of the insulation. Not good when one is (-) and the other is (+).
Thank god you had secure fuel lines from the tank:eek.
