rocket8189
New member
Last couple starts, noticed the steering column lock actuator motor didn't sound as strong as before. Began searching possible problems, went immediately to C4C5's article on "Steering Column Lock" workshop.
Checked my battery per article above, Solar battery tester showed 12.04 volts and 519 CCA, battery rated at 640 CCA, car was driven yesterday, driven regularly every other day or so, some times more often. Battery is about 4 years old, replacement for original---AC/Delco 86-6YR, 640CCA. Know replacement should be AC/Delco 78-6YR Professional with 120RC. It appears AC/Delco no longer produces this model and call to local AC dealer recommended I call Chevy dealer to see about a battery. I checked a forum today that indicated dealer no longer can get this battery, additionally AC/Delco 86-6YR in no longer available.
I have not received any DIC messages, only weakness is Solar as indicated above. When I cycled through the Solar tests, its last test indicated the battery needed to be charged; makes me think its time for replacement.
What's the best I can get for this application since it appears AC/Delco 78-6YR Professional with 120RC is no longer available?
Thanks in advance for your help,
Ken
Ken
