Neon in the gills? Nah.... (Pics)
  • Thread starter Thread starter Preacher
beamer said:
the neon sounds like a interesting idea. I have a silver collectors edition - 96. what color should I use. I like the idea of flames coming out of the gills. How did you wire them to the turn signals/directional markers. thanks for any info.
You could put a Neon in the gills to use as a decoration but you can't use them as turn signals becuase the cycle time is too long. You would be better off using LED's, small trailer brake lights or LED rope lights if you want them to work as signals.
To wire them up, simply tap into the front side turn signal wires. They will come on when you turn the running lights on and function as turn signals as well. Be sure to test them before final installation. When I installed, they would only work as running lights until I switched the wires. One way just running lights, the other way, both running lights and turn signals.... (You have a 50/50 chance of getting it right the first time as it is only 2 wires.. Heh)
