New Brake Lines
  • Thread starter Thread starter tscott9330
T
tscott9330
Alright, so I put the body on the frame a few months ago. However I failed to think about the brake lines that run arond the frame. i am going to use the pre-bent ones from ecklers.
My question is can this be done with the body on the frame or must I lift the boby to do this?
Tom
I just did my 75 a couple of weeks ago with prebent lines from Corvette Central. I was expecting a horror show but it turned out not bad at all. The only tricky part was making the bend up thru and around the trailing arm area but it was just a little wiggling around and it went right up and thru. I think I put that area in first, then worked it up on top of the frame. Some of the bolts were hidden a little and I had to take my time with an open end wrench, but no big deal.
I did have my exhaust system out for another reason so I did have a little extra room to work but I don't think it would be necessary to do that.
Good luck........Bill
Thanks Bill
That makes me feel better. At least I know it can be done.
Tom
