SANOLS1
I recently installed a new Baer Eradi Speed+1 Rotor Package-2pc. Fr/2pc. Rr brake rotors on my 04 coupe. I just didn’t like the look of the rear wheels with those small disks and thought the larger ones filled the wheel and added a nicer look to the car with the drilled and slotted disks. The front rotors are the same size as original but the new rear disks are 2” larger than stock, hence the caliper is moved outboard 1” to accommodate.
“The result in the rear is increased performance by virtue of the augmented leverage of the larger rotor. Baer provides all the hardware necessary to move the location of the OEM calipers outward.”
My question is, “Is there a need to adjust the brake bias due to the increased capability of the rear calipers?” If so, “Is there an adjustment I can make myself or would it require a new manifold or valve? It is actually noticeable under hard braking that the rears are pending skid sooner than as with the stock rotors. Anyone?
:confused
:confused
