S
sscam69
Well you can read about the supercharger on the "supercharger post"
Here is my delima.
I have close to $800 for some upgrades to the engine and can have $2k by the end of summer.I am getting the feeling the cam is more feasible than the supercharger as you might of have read in the post.
The engine has just been rebuilt but it does not put out enough power. I had asked for a hi lift cam didn't happen. There was confusion at the shop. Anyways I am really happy with the build as they did a good job. I am seeking at least 400hp--400ft-lbs of torque on a streetable engine.
I have a lot of good components already.
Dual exhaust
Single plane manifold (can purchase a dual plane if necessary for streetability)
Headers
Holley street avenger carb (670 cfm)
and other goodies.....
rpounds changed out the cam with the block inside the engine. I had never heard of anybody doing this and a big light bulb went off in my head.
I can afford the cam, lifters, springs and pushrods necessary for the performance of the cam. I figured while I was at it put in some new (better I think) heads but not necessary. What I mean by this is I think the heads are the stock heads but not sure (where can i find the casting #'s). What I do know is that they are ported and have 2.02/1.6 valves. The heads are going to require machine work for the springs anyways so I figured get some better flowing heads.
Does anybody know the flow numbers for stock heads? I would change the heads under the assumption that they flow better than the originals.
Obviously Vortech heads are the way to go on my budget. They can easily get expensive with the machine work though. 3-angle back cut, pocketed and ported, new valves 2.02-1.6, and machine work for the springs. I figure these heads will cost me the $800 alone.
As far as the work is concerned I will be doing it myself to save cash and can get some help from some gearhead friends. Thier payments consist of a few six packs.
reminds me just like the commercial
New camshaft for your engine $200 dollars
Beer for your friends as payment for their help $50
400 horses at your command PRICELESS.....LOL
Ok back to the post
Camshafts I am considering
Comp Cams
#Magnum 292H
Hydraulic flat tappet duration 244int/244exh @.05" with .501/.501 lift respectively.
#Xtreme Energy
Hydraulic Flat Tappet duration 240int/246exh @.05 .507/.510 lift respectively
any suggestions or comments on what I should do. I am always willing to hear out experienced folk.
sscam69
Here is my delima.
Dual exhaust
Headers
Ok back to the post
Comp Cams
#Magnum 292H
#Xtreme Energy
sscam69
