- Thread starter
- #21
S
sscam69
Even if I had zero deck clearance I would probably not be able to run it because I do know that the pistons are cast. I saw them before the mechanic installed them. But as you mentioned when i do take them off I am going to check the depth of the piston at TDC. That will allow me to run a thin gasket and ruduce that quench depth.
How hard is it to turn that crank with a ratchet and the tranny installed? I have a manual tranny.
I think more than likely I am going to start grad school and in that case I am going to ask the mechanic if I help him out if he will show me how to build engines.
As for the heads I am looking for someone that can sell me those
Vortechs with
-3 angle back-cut
-2.02/1.6 valves
-ported
-screw in studs
-stainless steel valves
-I think I need high performance springs (lift >.47)
all you have to do is just bolt them on.
supposedly the mechanic said he put a cam with 282 degrees duration with .48" lift. That should be putting out some good power but it isn't. My dad told my you can tell just by the sound when the engine is putting out that much power and you can feel it. My bro tested a Trans-Am 02' and he said that thing would whomp on my a$$. That made me very depressed because I thought I had a powerful car. I talked to friend and we went for a cruise and he said it was still pulling strong at the top so I am not to sure WHAT i have in this thing. That can be very frustrating.
Thats the reason I want to change the cam and the heads.
Frank
sscam69
Vortechs with
-3 angle back-cut
-2.02/1.6 valves
-ported
-screw in studs
Frank
sscam69
as well. I have almost gotten hit by two because they had turbos and thought they were all that. I swear if one of those chumps hit me I would pull them over and kick the door on of their cars.
ad The racing in North Houston is alright, but the spectators are just too close to the action. I once saw a Firebird fishtail and nearly take out four people. Two of which were kids. What moron parent lets their 8 yr. old get that close to a staging car?!
