paul79 said:Well, even a simple 327/300 throttle arm is too enemic for you fellows with the big motors.
We like everything big.
IH2LOSE said:Mark on my 66 It seems as if it would be easyer to reach up from the bottom of the car to loosen the nut that holds the arm(inside the engine compartment) to the pedal assembly.
paul79 said:Well, even a simple 327/300 throttle arm is too enemic for you fellows with the big motors. Glad things are coming together!
65-StingRay said:Hey VNV I changed my SB accel. lever out of my '65 two years ago. I had the small block lever on my BB car for years and had many of the same problems with length and throw which led to adjustment problems. I then ordered the big block lever for the '65.
Just ran outside to the garage to have a look at mine. I know it's different than the SB. It's kinda hard to describe how it looks. But curved up and wide toward the intake from the firewall. It does not touch the intake.
I tried to install it myself but my hands are too large. I had one of the guys at the local corv. shop with smaller hands do the work. He had also done this before on his '67. He said he swore a little but got it in.
You have a 5-spd tranny, correct. This will likely take up more hand space and make it tougher to put on that new lever. But I couldn't be sure on this.
If you want I could E-mail you a picture or two if you need to see what mine looks like.
After the conversion everything was better i.e. gas pedal had a better angle on it, the throw was right, it went in the correct hole on the carb., and there was no interference. Plus it's stock looking which I like.
65-StingRay
Wayne
E.F.D.
