T
Towu4free
No,Never got a bad set of injectors from Jon or Jon,Always been a perfect set!!adput some new injectors in my vette from FIC they were actually rebuilt anyway i installed them and started her up ran fine for about 2 mins then almost shut off and ran like **** and fuel was literally coming out the tail pipes looked like a smoke machine!!! getting another set today from FIC those guys (Jon and Jon) seem to be very friendly and helpful hope this new set works im going on a 4hr trip when i get the bolts tightend up:ugh any of you experiance this?
well jon hooked me up with another set and the fuel smoke is fixed i also put new plugs in it however, now when i start it after its been sitting it starts a little diffrent and i dont like it...instead of firing right up it stumbles/idles up from a low very low idle start, almost as if it is getting more fuel at start up, maybe a little to much....any of you encounter this problem? it seems to idle roughly in gear almost lik a wire is arking but i cant see that that is happeningregulator is good and new so is pump and filter, im putting in a new set tomorrow to see how it goes, i think i fluid locked one of the cylinders it whirled over a few times the other day and then stopped and wouldnt crank.. should i take the plugs out and whirl it over or do you think the fuel has evaporated and seeped down enough over a 36 hr time? thanks guys
Exactly what part number injectors did you buy from FIC? I bought 2 sets from Jon and they worked great.well jon hooked me up with another set and the fuel smoke is fixed i also put new plugs in it however, now when i start it after its been sitting it starts a little diffrent and i dont like it...instead of firing right up it stumbles/idles up from a low very low idle start, almost as if it is getting more fuel at start up, maybe a little to much....any of you encounter this problem? it seems to idle roughly in gear almost lik a wire is arking but i cant see that that is happening
the second set he sent me were much better, i believe i had dirt in there and it crudded up the injector (my fault not his) and he still sent me another set very very very good people if you ask me, but i just now reset my ecm (i also installed a new MAF) so well see how it does, if it doesnt fix it i guess my next step short of hooking it to a scanner would be to trade in for aExactly what part number injectors did you buy from FIC? I bought 2 sets from Jon and they worked great.
CG
Probly will till the ECM relearns all the parameters,Might take as much as 30-60 miles of normal driving!!but at idle it just seems a tad bit jerky i cant stand it lol maybe this problem is coming from my MAF ENDS? THANKS GUYS!![]()
I know you said previously you had installed new "MAF" ends, but now you are saying that you installed a new "MAF" too? If this is the case and you installed a new MAF (not the ends), then you may need a little tuning done to smooth out the idle. MAF's can be 25 ~ 35% off compared to each other. A new Bosch MAF was installed in an '87 Camaro I bought and I had to retune the air calibration because it was way off (lean).the second set he sent me were much better, i believe i had dirt in there and it crudded up the injector (my fault not his) and he still sent me another set very very very good people if you ask me, but i just now reset my ecm (i also installed a new MAF) so well see how it does, if it doesnt fix it i guess my next step short of hooking it to a scanner would be to trade in for aChevette....little bit of chevelle little bit of vette...
the car still hauls A** and will spank my friends WS6 but at idle it just seems a tad bit jerky i cant stand it lol maybe this problem is coming from my MAF ENDS? THANKS GUYS!![]()
yes i did install both new MAF and Ends,I know you said previously you had installed new "MAF" ends, but now you are saying that you installed a new "MAF" too? If this is the case and you installed a new MAF (not the ends), then you may need a little tuning done to smooth out the idle. MAF's can be 25 ~ 35% off compared to each other. A new Bosch MAF was installed in an '87 Camaro I bought and I had to retune the air calibration because it was way off (lean).
CG
How far have you driven the car??:confusedi put the stock injectors back in and it cleared up the starting issue and helped the idle a loti believe i had a vaccum leak around one of the injectors it wasnt sealed correctly in my intake but i went ahead and put the stock ones back in...anybody know what else could cause a rough idle?
When I started to modify my '92 LT1, the idle was the first thing I noticed that needed retuning. Even though the '92 LT1 is a "MAP" system (versus MAF / MAF-MAP), it is very particular about idle settings. Seems like the PCM cannot adjust, for idle, too easily at low air flows like idle. I eventually got the idle correct (smooth), but I had to burn a few EEPROMS and data log. (FYI - I took out the OE UV PROM and converted it to EEPROM)
CG
