- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,555
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
With no plenum to use for a vacuum source that is a problem. Hey Herb, still have the road draft tube?
How about using the cool Moroso can and the tubes to the valve covers for the intake and then use a pan evacuation systen in the exhaust to draw out the bad? Then you have a source of clean air in and a vacuum pulling fumes out without worrying about running it through the cylinders. As long as the rings and valve guides/seals are good very little oil should be pulled out of the exhaust, if any.
Otherwise, with the individual runners and no common plenum you would either have to pick one cylinder to be the PCV vacuum or drill all 8 and make a small diameter tubing manifold that would draw through a common pcv valve plumbed into one valve cover with the fresh air entering the other.
I'm getting confused. I think I'll go out and work on something simple. :L
otfl
