waterboy1976
- Joined
- Aug 18, 2003
- Messages
- 510
- Location
- Cleveland,Ohio
- Corvette
- 1973 4-speed Coupe FOR SALE/ SOLD!!!!
OK heres the scenario (although it really happened)
Cruising the other night...just got the motor done...no more than 450 miles on her since everything was redone.
Engine... 350 4 bolt .40 over Dart Iron Eagle heads (2.02/1.96 180cc runner 64 cc chambers slightly shaved 100thous) Cam...Edelbrock 7102....234/244 @50 lift 488/510......Rockers Comp cams 1.6 rollers....total adjusted lift exhaust side .544 Elgin springs part #rv943x Single damper spring high rpm max lift .550.
Why did my exhaust valve spring on number 1 cyl break?
All clearances are well within specs. No coil bind. Seat pressure good etc.
I called the guy who built myheads and he recommended to go to a .600 lift spring if Im in the pedal a lot. Now wait a minute....when your idling at 900 rpm Im still at .544 lift on the e side or when Im at 5600 rpm Im STILL at .544 lift...it shouldnt change....I would think at TOO high RPM youd have valve float and coil bind NOT a spring breaking.........Help......I have to real good friends who run in the superstock class at our local circle track and both of them tell me it sounds like a bad spring thats all....Any suggestions???
