- Thread starter
- #21
Marv02
Happy Days
I found It why It bent the push Rods.
Like I said This is the First time I set up a motor with Trick Flow Heads And This also a First for Roller Rocker Arms.
I never Used A Push Rod Checker Before either I read all the Info you put out And tryed My best to understand how to use A Push Rod Checker.
Here A link that has Pictures which showed how use them Now I Know What was Screwed Up.
Setting Pushrods Length, Quick and Easy- Car Craft Magazine
First I put The Good Push rods back on #1 Cly And rechecked today And guess what The intake was Bend once Again.
After doing and seeing what to look for the push rods I have are 7.794 long good for the Exhaust but the Intake needs to be 7.700.
the roller tip was sitting on the lower part of the vavle stem not the center.
I dont know if the Heads or Cam why The Intake needs a shorter push rod but at least I know Why It is bending Push Rods Now.
The weird part of it it was not bending them when you turn it over by hand only with the starter motor.
eadHorse:
