New Muffler Spacing
Hoosier66
Indiana
1987 Coupe,Blue on Blue, Z-51, 4+3, etc.
I just installed a set of Flowmasters on my 87. Does anyone know what the proper spacing should be between the mufflers and the cutouts?
It's usually a little less than an inch. Once you get both the mufflers lined up, they should pretty much space themselves.
Thanks, the outer tubes are ok, but my inner tubes are about 1/8 an in. from the body. Way too close I think. Back to the garage..
If you need something to raise and lower the pipes, use a jack. It works wonders and you can move it in small increments to get it just right.
