96 LT4 with 90,000 miles and Delteq. Been running perfectly with Delteq for more than 2 years. Water pump was leaking again so decided to replace opti at the same time as I replaced the pump after reading horror stories here. Found opti on ebay for $149 as referenced elsewhere --depicted as "brand new made by the same supplier who makes Delco units"-- PN1104032--see Ebay post below. After removing old opti a goodly amount of oil dripped out of opti vacuum vent line??? Vent lines were also softened at the opti by oil contamination.
Replaced opti and pump along with new opti vent lines and opti drive seal. Started right up. A soon as you take RPM up to 4800 (every time) either under load or in the driveway, get severe missfire--"poping and banging." Everything ran fine right up to redline before doing this. Suggestions as to where to start looking would be appreciated.
http://cgi.ebay.com/ebaymotors/ws/e...m=150183112370&ssPageName=ADME:B:EOIBSA:MT:11
