Peer81
Hello everybody.
Since I have my rebuild engine I put a new or rebuild starter under it because the old one got heat soaked. As it is the starter has about 450 miles on it. The problem occurs when the engine is hot and cold! What is the problem. When I want to start the engine something the starter starts working the first time but sometimes after the 4th try. What do I do? Very simple, key in contact, transmission in P, turn the key, I hear the solenoid from the starter click but nothing, the lights dim a little and the volt meter does a small step back. I put the key back in the zero position and try again, somethings just the click, sometimes the starter starts working. It doen’t matter if the engine is hot or cold. Previously I was thinking about the switch on top of the steering column but I changed that one with no luck. As I hear the solenoid click I think the problem is somewhere in or near the starter. I also checked all the wires, nothing wrong and nothing burned.
What is the difference with a heat soaked starter. Mine always starts within 1 minute, hot or cold. Anybody with some other idea’s?
Greetings Peter
Greetings Peter
