They evidently do quality checks by fitting them to an actual vette top and because my first set was rejected they sent a second set already preadjusted. Problem was I couldn't get them on the car, they were too tight. They told me I needed to loosen the tabs to install and then retighten. Said that I needed to get the air out of the seals . . . sounded a little questionable. Did that Friday afternoon and got them in and have not tried removing them. I understand using the shims and adjusting the fit, even though I would have expected if they are preadjusted that there should be very little of that. They sit level and square, but leaked when I washed it yesterday. I did order an AIM on Friday and should have it this week. I just wondered if I should expect preadjusted tops to leak. I suppose it makes sense that every car is unique and may require some tweaking. Thanks for your help! Dave
