79 money pit
New member
Just put new tires on and had an alignment done on my 79. What a difference in handling. Now I need to find the location of the horn relay to get the horn working. Ok at steering column.
Horns work with jumping power to them. Replaced the horn button and push pin. Still h thinking relay. Did not see mine above the fuse panel. Thanks for the replies.Your horns are very likely no good so I would test them first. Make sure they are well grounded then apply 12 volts to their HOT terminals.
