clugnut
Hello forum! My name is Jon and I am a new member here. I have owned my yellow 92 M6 for 11 years. It has been a great car for me, although recently it has been giving me fits. I am hoping the tech geniuses on here might be able to give me some direction.
I been having an interrmitent problem with my car throwing out codes after it has been warmed up. It has now become very predictable, so much so that I can almost make it happen. The car needs to be driven for at least 20-25 minutes, until the temperature climbs up into the 210-225 degree range. Sometimes, the lights will come on at this point, but not often. Many times to make the lights come on, it requires that the car is parked and turned off, let sit for about 5 minutes, then attempted to be started again. This is when the magic happens. The sys and security lights flash, and the service asr light is lit. At this point, I can almost be assured the car will not start if I turn it over. The motor spins, but it will not fire. I know that I do not have spark when this happens; we checked it at the mechanics. After a cool down period, usually only about 5 minutes, the car will fire and I'll be on my way. If the lights come on while I am driving, the car will remain running and run normally. It does not stall or act funny, it only does not refire if shut off and not allowed to cool.
Using the excellant resources on this site, I scanned the CCM for codes. I am getting codes 41, 54, and 72. 41 and 72 happen every time the codes happen, and 54 is a new one. According to what I'm reading, 41 is ECM Data Comm lost, 54 is FEDS, and 72 is serial data link error. Sounds like the machines ain't talkin'. Most times, these are history codes, but the last time I scanned it, the car was acting up, and code 41 was a C41. Luckily at this point, the car hasn't left me sit for more then 5 minutes, but if I can fix it, that would be great.
I have been working on this problem for about 2 years. The mechanics haven't fixed it, so I'm going to try to learn as much as I can and do it myself. Off the top of my head, here are the parts I have replaced.
New opti
New ignition module
New coil
Remanufactored ECM (A Corvette Central article says most code 41's are caused by this)
I have service manuals on the way. I am afraid at this point the ECM is looking like a possible culprit, which scares me. I know they are scarce, and I do not know what I will do if I need one. Anyway, I appreciate this forum already, and if anyone could point me in a direction or offer some advice, I'm all ears and ready to learn. Thanks in advance!
New opti
New ignition module
New coil
