[NEWS] GM, Bosch Team with Stanford on Technology to Make Gas Engines 20 Percent More
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
FOR RELEASE: 2005-08-16
GM, Bosch Team with Stanford on Technology to Make Gas Engines 20 Percent More Efficient, with Near-Zero Emissions
Would Improve Diesels, Hybrids Too
Palo Alto, Calif. -General Motors Corp., the Robert Bosch Corp., and Stanford University are developing a cost-effective engine technology that makes gasoline engines much more efficient and diesel engines much cleaner, for both conventional and hybrid propulsion systems.
Under a three-year, $2.5 million program announced today, GM, Bosch and Stanford researchers will work to accelerate the development of Homogeneous Charge Compression Ignition, or HCCI, which is a research technology that has the potential to dramatically improve the efficiency of gasoline and hybrid propulsion systems by more efficiently burning the fuel. HCCI could enable the improvement of gasoline engine fuel efficiency by 20 percent, while achieving near-zero oxide of nitrogen (NOx) emissions and particulates - contributors to ozone depletion and smog.
According to Dr. Gary Smyth, director of Powertrain Systems Research Lab, GM Research & Development and Strategic Planning, "It is GM's goal to develop and demonstrate the viability of HCCI -- a clean, efficient combustion process -- within the next few years. The joint program will allow us to expand the scope of controls, sensors, and actuators work beyond what we're already doing toward this goal."
This technology is attractive, as HCCI engines have the potential to provide a dramatic increase in fuel efficiency over conventional port fuel-injection spark-ignition engines and can run with diesel-like efficiency, but produce near zero particulates and very low NOx emissions. "For example," Smyth said, "gasoline engines could achieve 80% of diesel engine efficiency for about 50 percent of the cost."
In the HCCI engine, fuel is uniformly mixed with air (hence, "homogeneous charge), as in a spark-ignition engine, but with a higher proportion of air to fuel. Rather than using a spark plug to ignite the air-fuel mixture, however, the mixture is compressed by the piston until rising temperatures inside the chamber ignites it spontaneously - a process similar to that used in a diesel engine (hence, "compression ignition"), but at a much lower temperature. The lower combustion temperature combined with the high ratio of air to fuel, known as lean operation, virtually eliminates NOx emissions and lowers throttling losses, which leads to a significant boost in fuel economy.
Despite the advantages offered by HCCI engines, controlling HCCI combustion in the real-world environment versus the lab environment is a major hurdle for its commercialization, according to Dr. Patrick Popp, director of Electrical & Controls Integration Lab, GM Research & Development and Strategic Planning. "For it to be successful, HCCI will require development of advanced control technology and systems to make it robust. The development of critical sensors and actuators, along with control systems, will allow us to maximize the performance of the combustion system during transient operation, and comprehend the variation in fuels found around the globe."
Dr. Rolf Leonhard, executive vice president, Engineering Gasoline Systems Division, Robert Bosch GmbH, believes that HCCI could be a very promising technology for future generations of gasoline engines. "It is simply a better way to combust, providing large gains in fuel economy," Leonhard stated. "Due to the 'cold' HCCI combustion, engine raw emissions can be drastically reduced, offering the potential to meet emission standards with a cost effective three-way catalyst. However, stable and satisfactory operation of an HCCI engine is not possible without further development and sophistication of sensors, actuators and feedback control systems. The goal at the end of the day will be to suggest a complete engine controls solution that is both robust and cost effective."
The Bosch Group, specifically the Bosch Research and Technology Center (Bosch RTC) in Palo Alto, CA, in conjunction with Stanford, have already been working on advanced system technology for HCCI combustion control. During the same timeframe, GM's global research and development team, in cooperation with a number of other universities and suppliers in both North America and Europe, has developed an HCCI combustion system concept, base engine architecture, and operating strategy that allows the operation of HCCI over a broad engine speed and load range.
The interaction between industrial and academic researchers is central to this project. "Stanford's real strength is the ability to offer new perspectives on problems," stated Professor Chris Gerdes of Stanford University. "In the case of HCCI, we have demonstrated how the physics of combustion can be used as a model for the control system, tightly linking the fields of combustion and control. We are excited to now be partnered with GM and Bosch to help bring these ideas from the lab to the road," Gerdes said.
According to Dr. Smyth, the joint program nicely blends the two company's needs, as GM explores the potential commercial implementation of HCCI engines, and Bosch strives to develop the technologies critical to the manufacture of key HCCI sensors and actuators. "We bring engine, combustion and control system experience along with key operating strategies," Dr. Smyth said. "Bosch and Stanford supply control system experience along with knowledge associated with critical sensors and actuators."
General Motors Corporation
General Motors Corp. (NYSE: GM), the world's largest automaker, has been the global industry sales leader since 1931. Founded in 1908, GM today employs about 317,000 people around the world. It has manufacturing operations in 32 countries
and its vehicles are sold in 200 countries. In 2004, GM sold nearly 9 million cars and trucks globally, up 4 percent and the second-highest total in the company's history. GM's global headquarters are at the GM Renaissance Center in Detroit. More information on GM can be found at www.gm.com
Bosch Group
The Bosch Group is a leading global manufacturer of automotive and industrial technology, consumer goods, and building technology. In fiscal 2004, some 242,000 associates generated sales of 40 billion euros. Set up in Stuttgart in 1886 by Robert Bosch (1861-1942) as "Workshop for Precision Mechanics and Electrical Engineering," the Bosch Group today comprises a manufacturing, sales, and after-sales service network of some 260 subsidiaries and more than 10,000 service centers in over 130 countries.
In North America, the Bosch Group manufactures and markets automotive original equipment and aftermarket products, industrial automation and mobile products, power tools and accessories, security technology, packaging equipment and household appliances. Bosch employs nearly 23,000 associates in more than 80 primary and 20 associated facilities throughout North America and reported sales of $7.8 billion in 2004. For more information, visit
www.boschus.com.
Stanford University
Founded in 1885, Stanford University is recognized as one of the world's leading research and teaching institutions. Its current community of scholars includes 16 Nobel Prize winners, four Pulitzer Prize recipients and 22 MacArthur Fellows. Because of the academic excellence of its more than 1,700 faculty members, Stanford is uniquely positioned to pursue interdisciplinary solutions to the world's most daunting problems. The areas of excellence cross disciplines and range from the humanities to social sciences to engineering and the sciences, and the professions of business, education, law and medicine. Stanford's 14,000 students--7,500 graduate students and 6,500 undergraduate students--are drawn from an international pool of accomplished and talented young scholars.
