96corvetteLT4
I tested with the key on, trans in reverse, engine off. I have checked bulbs, fuse in  box on pass side of dash, and transmission connector.  I did not unplug the trans connector because it is too diffuclt to reach, but it is fully seated.  There are two connectors on the driver's side of the trans, one that connects to an external module, midway back, that is the 1-4 skip, and another at the top front that I an guessing is the reverse lights.  The only other connector I could find was the speed sensor connection.  All of the other tail lights work, so it does not look like a ground problem.
Is there another connector that I am missing? Is there a way to check the reverse light switch on the trans without removing the clutch slave cylinder?
I am in no hurry to get it fixed, but need to before state inspection time.
