no build sheet 1975
chevy6673
illinois,crete
1973 Corvette ,1966 ss impala
took my gas tank down today was hoping to find a build sheet but no luck, had to fix hole in hose on top of tank ,:ugh
Vette79
Millersville, MD
1979 L-48 Black Coupe
Bet you were dissappointed? Did it appear to of had a build sheet glued to it? If not, have you looked behind your instrument panel and under the carpet yet? You never know...
chevy6673
illinois,crete
yes i was very dissappointed i also took of the calipers today that was enough work for one day ..i do plan on looking in these places sooner or later .
6880 Mike
The Bluegrass State
1968 convertible; 1980 L-82
Your car probably had the build sheet stuck on the front of the tank as shown. The original was probably gone a long time ago.
Copies of build sheets have been found in the wiring behind the speedo/tach; in the wiring behind the center cluster; behind either kick panel; tucked in the springs beneath a seat, and under the carpet in the rear storage area. In one documented instance, a copy of the build sheet was folded and placed behind the rear spring shackle.
