401KVet
;help I will try to make a long story short, but with all the details. Up until 10/2011 all was good until I broke a bleeder screw on the right rear caliper. I had been having brake issues with soft pedals and the brake light coming on a lot. I would bleed, then good for a week or two, then same thing over again. So I decided to replaced all calipers, lines, etc. with O-ring calipers. Because of money this has been a very slow process. But in the mean time I decided to replaced the CENTER BEZEL and the CENTER SHIFTER CONSOLE. This past September I got all of that back together, except for the two carpet side panels. I ran the car at idle testing everthing to make sure all the gauges were working, ac, cig. lighter etc. etc. When I started and ran the car, just idling for testing, I did notice that the battery seemed a little low from sitting for such a long time. Almost a year. The battery is less than two years old. One of Napa's best. I took it out, charged it up to a full charge, cleaned all of the cables and connections. Started the car up and all still looked good. All gauges working, all lights, power windows, etc. Now fast forward to last week. I peeked in the car and noticed that the clock was not running anymore. I thought maybe the battery may have gone complety dead this time, so today I was going to charge it up again. But thinking this was odd, I hooked up the charger and the charger said the battery was almost fully charged. I have no ligths at all, not even interior lights. The second hand on the clock is not moving as it always is. No ignition at all when turning the key. I then went ahead and pulled the cables off to look at all connections, and all are good and clean, and all was tight. At this point I tend to believe my battery charger that's telling me the battery is good. But I have no juice anywhere. I know this is just a process of elimination, but where do I start? Has anyone had this type of prolbem before?
