Help! no pwr to instrument light fuse position
tomgok
ok
76 L-48,coupe
I noticed no instrument lights and checked fuse,it was OK. I checked for power at the fuse and there is none at that position. Anyone else have this issue?
Did you check both sides of the fuse without the fuse in place ???
If so follow the wire that powers it back to it beginning. Then there should a break some where.
It's going to be a PIA but it may be the only way.
Good Luck
Sent from my DROID RAZR using Tapatalk 2
Thanks, I found a broken connection at the back of the fuse box. Yes it was a PIA.
