C
c4ever
I thought I had this licked last week but got the phone call yesterday from the wife. 82 needs a jump.
ad
It goes like this. Car will crank fine for maybe a couple of days or it may crank , run it for a minute, shut her down, go to re-start. no crank. Starter does not make a peep but battery meters 12.53 volts. Put a jump on her, starts right up. Battery seems to be getting good charge 14.2 when metered running. Battery is new(3 months old AC Delco), starter is new, all connections and grounds are good. I thought possibly a neutral safety switch or purple ignition wire but if these were the case I wouldn't think a jump would do any good. I've come to the conclusion it's just a bad battery. Can a battery meter 12.5 volts but not have the ability to engage the starter? In addition, all lights, dash lights are strong as if the battery was fine but no crank. Put a jump on her starts right up
ad It's really starting to get to me. BG is days away. I don't need this now
So can I have a bad cell which seems to have proper voltage but no cranking amps?
Sorry if this is long but I tried to explain to the best of my ability.
Thanks guys and girls
Carlo
;help ;help ;help
ad It goes like this. Car will crank fine for maybe a couple of days or it may crank , run it for a minute, shut her down, go to re-start. no crank. Starter does not make a peep but battery meters 12.53 volts. Put a jump on her, starts right up. Battery seems to be getting good charge 14.2 when metered running. Battery is new(3 months old AC Delco), starter is new, all connections and grounds are good. I thought possibly a neutral safety switch or purple ignition wire but if these were the case I wouldn't think a jump would do any good. I've come to the conclusion it's just a bad battery. Can a battery meter 12.5 volts but not have the ability to engage the starter? In addition, all lights, dash lights are strong as if the battery was fine but no crank. Put a jump on her starts right up
Carlo
;help ;help ;help
