mystang
Okay lets back up again. I replaced rear main and oil pan, car ran fine after, then replaced valve cover gaskets, car ran fine. still noticed the car leaking so after much search discovered i may want to take a look at intake manifold and oil pressure sending unit. Took out distributor and pulled manifold. Resealed manifold, but I took the TBI off of the manifold which I now understand was a big NO NO. Instead of putting it back together i went in for the timing chain cover as it was also leaking, after putting it all back together tried to crank. It would crank, but no dice would not start. So started messing with clocking of the distributor and still no go. Let it sit for a few minutes thinking maybe flodded.
I then go to crank it and it starts but stumbles for about 10 seconds. Did this three times. Finally was quick enough to get the timing light on it and when I would put it at 6 Deg. Before TDC it would just make a ppsh sound and Die. So tried this a couple more times then it cranked and ran "fine". Except it idled High at 6 Deg. BTC and the headers would start to glow red after a few minutes throwing the codes listed above. I checked the Map sensor ground and voltage as well as output voltage. All check out to be good. This is weird as it threw a map sensor code and a coolant temp code.
Then about a week later I took another stab at it and now it would even start on its own, but it will crank until the battery dies. So thinking that I may have messed up on the timing chain went back in and took a look and re verified that I have dot to dot aligment with both sprockets. Also made sure that I was not 180 Deg. out with the distributor. As in when dot to dot it was pointed at #6 on the cap. So any ideas hnoes?
