MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
There are a lot of valve covers that don't have vent holes.
That leads to a few interesting topics/questions:
1: The crankcase needs to be vented. Preferrably, it needs to be evacuated (ie, connected to a vacuum source, to remove gasses forcibly). I've seen examples of cars which had a hole drilled through the intake manifold, into the valley, and another into the plenum, with a hose connecting them.
Will that properly vent the crankcase?
Would it be possible/practical to machine the hole for a PCV valve, rather than a hose barb, to have the proper operation? It's my understanding that the PCV valve operates as a check valve, so that crankcase doesn't suck air backwards through the vent. I would think that having the air&fuel mixture drawn into the crankcase would be a bad thing...
2: It's also my understanding that the valve covers need to be vented. The driver's-side one is vented by the PCV valve, and the passenger's-side one is vented to the air filter by a short hose (at least, that's how mine is set up). Wouldn't running non-vented valve covers present a problem, in that case?
3: How do you add oil? Similar to the first question, would it be possible to add oil through the cam/lifter valley, using a hole in the intake manifold?
Non-vented covers do present a much cleaner look, but these seem pretty important issues to address.
Joe
Joe
