- Joined
- Apr 8, 2005
- Messages
- 274
- Location
- Charleston, SC
- Corvette
- 1981 Dark Blue Metallic, 2003 AE coupe
What temp are you folks seeing your oil stabilize out at when running extended highway speeds (70-75mph) with about a mid 50's ambient temp? Mine is holding at about 210 (straight up) and I'm not used to seeing it up that high. The coolant temp is running around 170 or less during the same time. The heater contol is always off as the control panel slides are not functional at the moment. Only have a/c right now and it was off as well. The car is all original with 57K miles. Just wondering what was normal for the L81 as I don't usually do too much highway driving, but that seems to be changing. Thanks in advance for any inputs.
Mike
Mike
