bobmanx
- Joined
- Dec 29, 2002
- Messages
- 169
- Location
- Southern Calif.
- Corvette
- 1967 White Convert. 327/350hp, 4 spd, with A/C
Now for the Questions! Thanks
As I was told, "Be prepared for the Holley fuel bowls to leak after sitting unused", "they may leak a little or flood"! "The bowl gaskets dry out and when exposed to real Gas again they may not seal" ! They are allowing a small amount of gas to slowly seep out, and I have not tried to start the engine yet. What is the recomended method for dealing with this, other than "do not let it sit for a extended period of time again"?
Are new Holley float bowl gaskets available seperately? Keep tightening the screws and? What's best? New SS tank and fuel lines installed and Carb was rebuilt just prior to the car being stored and has not been run for at least two years.
The floor is open to suggestions . Dont want it to be a ongoing problem!
Stock 327/350 hp, 4 spd with AC. appears to be a stock Holley 4 barrel with stock air cleaner.
Thanks for the help and any suggestions.
Bob
Bob
