HallenTi
Several months ago, I corrected my large oil leak (common from what I understand) on the L98 engine in my 1990. So far, it has not leaked since.
My problem (or I think it is my problem anyway) is that the RTV included in the kit didn't say "sensor safe".
After the successful repair, I decided that some of my drivability problem could be from the O2 sensor, and since I had never changed it, I bought a Bosch unit from NAPA for about $21. After I put it in, the drivability problems were instantly gone and I was very happy... for a while. No other changes were made at that time other than the O2 sensor, so I am thinking that the RTV in the kit may have fouled up the new O2 sensor. But, since the RTV was used just on the front and back of the manifold, and a little bit to seal he edges of the paper gasket where it meets the RTV at the end, I am not positive of this... anyone have any thoughts? Will the RTV "eventually" stop giving off the fumes that cause the sensor problem? Could the sensor getting "fouled" be a coincidence and there be another problem instead (I sure don't wan to redo the job to find out it makes no difference)? The plugs (recently changed) look just fine - not rich or oily, etc.
While I don't want to redo the job again (this time, using RTV that I know is "sensor safe"), if this is likely to be the problem, I will do it to restore the drivability. Thanks, Tim
